12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- That is naughty. You are faking the initial value of sum using 255*sum at reset. --- Quote End --- What else should I do in order to achieve for example 100mA instead of 4 mA, 8 mA, 15 mA,.......100mA. I need stable value directly. What else can I do in the code?
