12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years agoIf the direct ADC values are incorrect, isnt this something for you to Debug? it would be easy to test this code does a rolling average in a simple testbench (you just pass a set of known values into the data_in port) so you can ensure this works before debugging any upstream problems.
