Constraint file for async_fifo macro?
Where is the constraint file for the async_fifo macro in quartus 23.4?
I get a bunch of CDC timing... why isn't it loaded by default with the module?
- TingJiangT_Intel
Contributor
To figure out your question, you are using fifo ip to perform asyn fifo function but there are timing violations in timing analyzer right?
If so can you share your project archived, you can remove your RTL file but please make sure the timing path can be showed in timing analyzer thanks.
- KennyT_altera
Not sure if you have update on the above? We will need your design to investigate on this.
- KennyT_altera
