8 years agoConstraining LEDs/Switches to VHDL onDE1-SoC
Hello, I am trying to write some basic VHDL that "slide" an on led down the 10 leds on the DE1-SoC board. I have loaded the .sof onto the board but nothing is lighting up. I think the VHDL is good be...
8 years agoI was able to constrain the VHDL clk, but now the tool says clk_div is unconstrained which I do not understand because it is just a clock generated based on the count of a register that is iterated by the tick of clk. Do I have to write a constraint in the sdc for this clock as well?
https://alteraforum.com/forum/attachment.php?attachmentid=15323&stc=1 in de1soc_master.qsfset_global_assignment -name FAMILY "Cyclone V" set_global_assignment -name DEVICE 5CSEMA5F31C6 set_global_assignment -name TOP_LEVEL_ENTITY "DE1_SoC" set_global_assignment -name DEVICE_FILTER_PACKAGE FBGA set_global_assignment -name CYCLONEII_RESERVE_NCEO_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name clk_gen.sdc# set_global_assignment -name SDC_FILE DE1_SoC.sdc new constraint clk_gen.sdc
create_clock -period 20 [get_ports clk]
