cjak's avatar
cjak
3 months ago
Constraining an unclocked output?
I am trying to achieve timing closure, but have trouble constraining outputs that is not referenced to an external clock. Do I have to define a false path for each output?
  • Hi,
    to declare all IO as asynchronous
    set_false_path -from [all_inputs]
    set_false_path -to [all_outputs]
  • FvM's avatar
    FvM
  • cjak's avatar
    cjak
    Thanks, but it is a bit unclear to me how I would define the false path:
    set_false_path -from [get_pins A*] -to [get_pins B*]
    ...when -from and -to is the same signal/net/pin?
    • KennyT_altera's avatar
      KennyT_altera
      • If a port (e.g., reset_in) is truly asynchronous and handled by a synchronizer, you cut the path from the port to the first synchronized flip-flop: set_false_path -from [get_ports reset_in]
  • sstrell's avatar
    sstrell
    If they're completely asynchronous outputs, yes, you would false path them.  You can use wildcards in your target for set_false_path if there are a lot of them.
