cjak
8 months agoConstraining an unclocked output?
Hi, I am trying to achieve timing closure, but have trouble constraining outputs that is not referenced to an external clock. Do I have to define a false path for each output?
- 8 months ago
to declare all IO as asynchronous
set_false_path -from [all_inputs]
set_false_path -to [all_outputs]
cjak
8 months agoThanks, but it is a bit unclear to me how I would define the false path:
set_false_path -from [get_pins A*] -to [get_pins B*]
...when -from and -to is the same signal/net/pin?
KennyT_altera
8 months ago- If a port (e.g., reset_in) is truly asynchronous and handled by a synchronizer, you cut the path from the port to the first synchronized flip-flop: set_false_path -from [get_ports reset_in]
