15 years agoconstant expression cannot contain a hierarchical identifier
Hi people,
I'm very new to SystemVerilog, and learning how to write synthesizable code right now. Could you help me with an issue? Please take a look at the code:typedef struct{
int a;
int b;
int c;
} params_t;
module A (clk, rst, out);
parameter params_t params = '{2, 3, 4};
input logic clk, rst;
output logic out; //line 12!
always @ (posedge clk, posedge rst) begin
if(rst == 1'b1) begin
out <= '0;
end else begin
out <= out + params.b;
end
end
endmodule Quartus II (9.1) gives an error at the line 12: "constant expression cannot contain a hierarchical identifier" The problem seems to be that I want to use parameters defined in a structure to make the design more generic. With VHDL it works fine. Am I allowed to do it in SV, or is it just Quartus issue? It would work if I would use the parameters without putting them into a structure, but it's ugly. How would you do it on my place?
