Connection bit order between hierarchy
- 2 months ago
Hi Masaru,
Thank you for the clarification.
After confirming once again with the Altera design team using the original design along with the information from the additional forum link that have been provided, this issue has been identified as a known software bug. As BDF has been deprecated and is no longer supported in newer Quartus releases, no fix is planned for this issue.
Here are some of the suggested workaround you may work with:1. Avoid using .bdf files by converting them to Verilog or VHDL in Quartus Prime Standard Edition using File → Create/Update → Create HDL Design File from Current File, and then use the generated HDL files in Quartus Prime Pro.
2. Replace the SystemVerilog top-level module with a VHDL, AHDL, or BDF top-level design to avoid the bus-ordering issue.
3. Continue using your existing workaround with the streaming operator (<<) to resolve the bus ordering.
We understand this may not be the outcome you were hoping for, and we apologize for the inconvenience. Please feel free to reach out if you have any further questions or concerns. If there are no further questions or updates, we may proceed with closing the support ticket accordingly.
ZiYingE_Altera
Hi Masaru,
ZiYingE_Altera
Hi Zi Ying,
Ok, I am happy with your workarounds.
I agree with closing this ticket.
Thank you for your help.
Masaru
- ZiYingE_Altera2 months ago
Contributor
Hi Masaru,
Thank you for the update and for taking the time to work with us. I will proceed with closing this ticket. However, we will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
ZiYingE_Altera
