18 years ago
Connecting nodes without wires
One of the tutorials I found online says that nodes can be connected without wires on complicated schematics.
"Since our example schematic is quite simple, it is easy to draw all the wires in the circuit without producing a messy diagram. However, in larger schematics some nodes that have to be connected may be far apart, in which case it is awkward to draw wires between them. In such cases the nodes are connected by assigning labels to them, instead of drawing wires. See Help for a more detailed description."
Help is no help. I read though all 165 entries when I searched "nodes". arg.
I right clicked on a node, choose properties, name the node. Then do the same to the signal to which I want to connect, giving it the same name.
It would seem that double clicling on one of the nodes should highlight both nodes with the same name, but it doesn't.
What is the correct way to do this?
