18 years ago
connect 2 PLLs in cyclone II
Hi all!
I create a project in cycloneII 35. I must use 2 PLLs from 1 external clock. So, I must connect them. But when I do this, there're many problems. For examples, when compiling there's error: "can't fit fan-out of node clk_dram (name of one PLL) into single clock region." Who knows how to solve this problem to use 2 PLLs in my project. Please tell me, thanks!:confused:
    Unfortunately you can't do that. As you can see in the page 7-26 and 7-27 of the cyclone II handbook, each PLL can be drived only by its dedicated input ports. Then there is no way to connect one source with two PLLs.
    I've tried to apply many ways. But, in the end I failed. Probadly, I can't do this. It means that I must use one separated input clock for each PLL. Is there any solution for this problem? Please show me! Thanks for Bee's helping!
    As said, Cyclone II doesn't support chaining of PLLs as you can do e. g. with Cyclone III.
    For this reason, I usually routed the main clock input "all around" the FPGA in Cyclone II designs. If you need a PLL function without strict timing requirements, you can probably output it to a pin next a dedicated clock input and route it through pins. A routing delay could be compensated by PLL phase shift.
    Maybe you can use two pins and use clock skew in order to compensate layout based delays.
