16 years agoI am confused by timequest timing analyser too
1. ------------------------------------------ QII gives the following critical warning: Critical Warning: The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command. Critical Warning: From CLK24 (Rise) to CLK24 (Rise) (hold) However, the SDC file definitely has the derive_clock_uncertainty command. What should I do? Should I add this command second time? 2. ------------------------------------------ sdc and timequest api reference manual (http://www.altera.com/literature/manual/mnl_sdctmq.pdf) does not describe virtual clocks. The create_clock command description states that <target> must be specified: create_clock [-add] [-name <clock_name>] -period <value> [-waveform <edge_list>] <targets> I am confused with virtual clocks. Somewhere I've red that I should use virtual clocks in the set_input_delay and set_output_delay commands. But I am not sure that I've created virtual clocks correctly. Should virtual clocks somehow relate to real clocks? 3. ------------------------------------------ Some SDC commands can use -add or -add_delay options. I am not sure when should I use this option. For instance, set_input_delay description in the API RefMan reads -add_delay: Add to existing delays instead of overriding them Does it mean that I can use only the very first set_input_delay command without -add_delay option?
