Configuration of Arria 10 Transceiver for JESD204C Rx-Tx Controller IIP
- 2 years ago
Hi Arasendran,
Apologize for the delayed response as we encounter some technical difficulty.
At the moment, for A10 device only support JESD204B, there is no support for JESD204C.
Regarding to transceiver, you may refer to below documentation on all the details you need for transceiver on Arria 10 device.
In this document mention on how to enable the transceiver toolkit, how to load the design, how to set the parameter setting, connection guideline and more.
Intel® Arria® 10 Transceiver PHY User Guide
Please do note that you need to implement the protocol as mentioned in section "2.3. Arria 10 Transceiver Protocols and PHY IP Support".
Intel encourage customer to use the latest version of Quartus software in order to avoid bugs and errors.
Here i attached the JESD204B design example for your reference.
Hope this answers your question.
Thank you.
ZH_Intel
Hi Arasendran,
Thank you.
ZH_Intel
