Concatenation operator in a port assignment ?
I'm using Quartus 18.1.1 / Build 646 and have observed a strange behavior with the following VHDL code:
meta_data_ram : altsyncram
generic map (
port map (
address_a => md_upper_reg & channel_inreg;
);The issue concerns the port "address_a": With Signal Tap I see the following values:
md_upper_reg = '1' and channel_inreg = "00000"
==> address_a is "000001" instead of "100000" as expected
When I change the code like this...
md_wr_addr <= md_upper_reg & channel_inreg;
generic map (
port map (
address_a => md_wr_addr,
.........everything works fine !!
If the compiler can't handle the concatenation operator in a port assignment I would expect that there is either an error or the signal assignment is done correctly!
Did I miss something or is this a Quartus issue?
- MEIYAN_L_Intel
I had found out that it might be due to the VHDL version used in Quartus.
For an example here:
In VHDL 2008:
comp_inst : comp
port map(
thing => "000" & sig
In VHDL 93:
tempsig <= "000" & sig;
comp_inst : comp
port map(
thing => tempsig
You may check your VHDL version in by clicking assignment >settings>VHDL input.
- RHerm1
Thanks for your reply,
I'm using VDHL 2008 and the issue is that a wrong value is assigned to the port "address_a". When I assign the same expression to a signal first and then this signal to a port it works!!
- MEIYAN_L_Intel
May I know any new issue facing?
