caron
7 years agoCompiling and Linking Your Kernels or Object Files without Building Hardware (-rtl) which don't work !
when I use " aoc -rtl <your_kernel_filename1>.cl". it issue an error : aoc: Running OpenCL parser.... error: unknown argument: '-rtl' Error: OpenCL parser FAILED. Refer to hello_world/hello_wo...
MMATT35
6 years agoHello KhaiY_Intel,
I have the same issue with this version :
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 19.1.0 Build 670 Standard Edition
Copyright (C) 2019 Intel Corporation
I downloaded this version : https://fpgasoftware.intel.com/opencl/19.1/?edition=standard&download_manager=direct
and the associated documentation explain howt to use -rtl : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf
Do you knouw why have this error ?
Thank you
