caron
7 years agoCompiling and Linking Your Kernels or Object Files without Building Hardware (-rtl) which don't work !
when I use " aoc -rtl <your_kernel_filename1>.cl". it issue an error : aoc: Running OpenCL parser.... error: unknown argument: '-rtl' Error: OpenCL parser FAILED. Refer to hello_world/hello_wo...
caron
7 years agoHi , thank you for your response !
my version is :
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 17.1.1 Build 273
Copyright (C) 2017 Intel Corporation
Maybe it is the version's problem.. How can I update the version ?? thank you .
- HRZ7 years ago
Indeed the -rtl switch is not available on Quartus v17.1.x. You can download all versions of Quartus from here:
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
However, you should make sure to use a version of Quartus that is compatible with the OpenCL BSP of your board. Consult the documents from your board manufacturer to determine what version of Quartus to use.
