compile my existing projects using scripts
- 2 years ago
The command qsys-script link here https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/generate-a-system-with-qsys-script.html will be used for the qsys .tcl. Then after source the .tcl the command qsys-generate link here https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/qsys-generate-command-line-options.html will be used on .ip and .qsys to generate the .qip file (GUI will be the Generate HDL in platform designer and IP Generation in Compilation Flow window)
Sheng
Sheng
