anonimcs
Contributor
2 years agoCompile a design from a copy of its qsys
Hi all, I want to use a qsys file that is mostly a copy of a previous version of the same project. I have a design that I can synthesize and implement on an Arria10 FPGA but due to obsolescence of a...
sstrell
2 years agoIs the .qsys your top-level design or are you instantiating the system in a higher-level design?
What files are listed under Add/Remove files and in the Timing Analyzer settings (.sdc files)?
anonimcs
Contributor
2 years agoThe qsys belongs to the top-level.
I have no files listed in the sdc file, just setting constraints and setting clock groups for the IPs used within the project. Under Add/remove Files, the following are listed: some qsys files for the IPs used in the project, 2 qip files for the IP's that are bought from other companies, top-level VHDL file, the sdc file.
