Compilation error
- 6 years ago
Hi, Tushar. That device should be supported, but in order for it to show up in the pull-down menu in the "Device" block, you must have that device family installed in the Quartus version that you are using when you start DSP Builder with (in your case Quartus 18.0.1). The menu, as you see it, should reflect the currently-installed devices for 18.0.1. You can use "Tools" -> "Install Devices" within Quartus to add device families, after downloading the files from Intel website.
Jeff
I am using MATLAB 2017b and Quartus II 18.0. I could get the solution by increasing the JAVA heap space memory in MATLAB.
Could you tell me whether it provides the device support for Stratix V (5SGSMD8K2F40C2) specifically. If yes, how do I get the board block in the DSP builder library?
Tushar
Jeff
