TTyag's avatar
TTyag
6 years ago
Compilation error
Hi, I am trying to compile a subsystem in DSP builder but everytime the MATLAB crashes. However it is able to compile the existing design examples. Any suggestions are welcome. DSP Builder
  • JeffC_Altera's avatar
    JeffC_Altera
    6 years ago
    Hi, Tushar. That device should be supported, but in order for it to show up in the pull-down menu in the "Device" block, you must have that device family installed in the Quartus version that you are using when you start DSP Builder with (in your case Quartus 18.0.1). The menu, as you see it, should reflect the currently-installed devices for 18.0.1. You can use "Tools" -> "Install Devices" within Quartus to add device families, after downloading the files from Intel website.
    Jeff
