Compilation error
- 6 years ago
Hi, Tushar. That device should be supported, but in order for it to show up in the pull-down menu in the "Device" block, you must have that device family installed in the Quartus version that you are using when you start DSP Builder with (in your case Quartus 18.0.1). The menu, as you see it, should reflect the currently-installed devices for 18.0.1. You can use "Tools" -> "Install Devices" within Quartus to add device families, after downloading the files from Intel website.
Jeff
As I understand it, you observe DSP Builder seems to crash when you are trying to compile your design. There is no issue when compiling the example design in the DSP Builder. By merely based on this, it seems like it is specific to your subsystem.
To ensure we are on the same page, just to check with you on the following:
1. What is the DSP Builder version and the Matlab version that you are using?
2. Mind further elaborate on the "crashes" observation? For example, what is the error message trigger?
3. Mind share further on the specific IP that you are using or the existing example design that you are running without issue.
Chee Pin
- TTyag6 years ago
I am using MATLAB 2017b and Quartus II 18.0. I could get the solution by increasing the JAVA heap space memory in MATLAB.
Could you tell me whether it provides the device support for Stratix V (5SGSMD8K2F40C2) specifically. If yes, how do I get the board block in the DSP builder library?
Tushar
- JeffC_Altera6 years ago
Jeff
