14 years ago
Code Review Request..
Dear all,
I'm writing a VHDL code which is demuxing coefficients. When it switches from one to the other, other coefficients should be remained previous values.
My code is following but looking at the real output coefficients are changing when I switch from one to the others. Please review the code and giving me a comment is much appreciated.
library ieee;
use ieee.std_logic_1164.all;
entity demux_coef is
port(
clk: in std_logic;
--- Coefficient Input Set 1
R_y3mm1: in std_logic_vector(11 downto 0);
J_y3mm1: in std_logic_vector(11 downto 0);
R_y3pp1: in std_logic_vector(11 downto 0);
J_y3pp1: in std_logic_vector(11 downto 0);
R_y3mp1: in std_logic_vector(11 downto 0);
J_y3mp1: in std_logic_vector(11 downto 0);
R_y3pm1: in std_logic_vector(11 downto 0);
J_y3pm1: in std_logic_vector(11 downto 0);
R_Alpa1: in std_logic_vector(11 downto 0);
J_Alpa1: in std_logic_vector(11 downto 0);
--- Coefficient Input Set 2
NL_17_param:in std_logic_vector(11 downto 0);
NL_18_param:in std_logic_vector(11 downto 0);
NL_19_param:in std_logic_vector(11 downto 0);
NL_20_param:in std_logic_vector(11 downto 0);
NL_21_param:in std_logic_vector(11 downto 0);
NL_22_param:in std_logic_vector(11 downto 0);
NL_23_param:in std_logic_vector(11 downto 0);
NL_24_param:in std_logic_vector(11 downto 0);
---- Demux
sel_coef: in std_logic_vector (1 downto 0);
--- Coefficient Output 1
alpha_UU2: out std_logic_vector(11 downto 0);
beta_UU2: out std_logic_vector(11 downto 0);
alpha_UL2: out std_logic_vector(11 downto 0);
beta_UL2: out std_logic_vector(11 downto 0);
alpha_UU4: out std_logic_vector(11 downto 0);
beta_UU4: out std_logic_vector(11 downto 0);
alpha_UL4: out std_logic_vector(11 downto 0);
beta_UL4: out std_logic_vector(11 downto 0);
alpha_UU2L2: out std_logic_vector(11 downto 0);
beta_UU2L2: out std_logic_vector(11 downto 0);
--- Coefficient Output 2
alpha_LU2: out std_logic_vector(11 downto 0);
beta_LU2: out std_logic_vector(11 downto 0);
alpha_LL2: out std_logic_vector(11 downto 0);
beta_LL2: out std_logic_vector(11 downto 0);
alpha_LU4: out std_logic_vector(11 downto 0);
beta_LU4: out std_logic_vector(11 downto 0);
alpha_LL4: out std_logic_vector(11 downto 0);
beta_LL4: out std_logic_vector(11 downto 0);
alpha_LU2L2: out std_logic_vector(11 downto 0);
beta_LU2L2: out std_logic_vector(11 downto 0);
--- Coefficient Output 3
small_a_p5: out std_logic_vector(11 downto 0);
LARGE_A_p5: out std_logic_vector(11 downto 0);
small_a_p3: out std_logic_vector(11 downto 0);
LARGE_A_p3: out std_logic_vector(11 downto 0);
small_b_p3: out std_logic_vector(11 downto 0);
LARGE_B_p3: out std_logic_vector(11 downto 0);
small_c_p3: out std_logic_vector(11 downto 0);
LARGE_C_p3: out std_logic_vector(11 downto 0);
--- Coefficient Output 4
small_a_m5: out std_logic_vector(11 downto 0);
LARGE_A_m5: out std_logic_vector(11 downto 0);
small_a_m3: out std_logic_vector(11 downto 0);
LARGE_A_m3: out std_logic_vector(11 downto 0);
small_b_m3: out std_logic_vector(11 downto 0);
LARGE_B_m3: out std_logic_vector(11 downto 0);
small_c_m3: out std_logic_vector(11 downto 0);
LARGE_C_m3: out std_logic_vector(11 downto 0)
end demux_coef;
architecture rtl of demux_coef is
begin
process(clk)
begin
if (sel_coef = "00") then -- Coefficient Output 1
alpha_UU2 <= R_y3mm1;
beta_UU2 <= J_y3mm1;
alpha_UL2 <= R_y3pp1;
beta_UL2 <= J_y3pp1;
alpha_UU4 <= R_y3mp1;
beta_UU4 <= J_y3mp1;
alpha_UL4 <= R_y3pm1;
beta_UL4 <= R_y3pm1;
alpha_UU2L2 <= R_Alpa1;
beta_UU2L2 <= J_Alpa1;
elsif (sel_coef = "01") then -- Coefficient Output 2
alpha_LU2 <= R_y3mm1;
beta_LU2 <= J_y3mm1;
alpha_LL2 <= R_y3pp1;
beta_LL2 <= J_y3pp1;
alpha_LU4 <= R_y3mp1;
beta_LU4 <= J_y3mp1;
alpha_LL4 <= R_y3pm1;
beta_LL4 <= R_y3pm1;
alpha_LU2L2 <= R_Alpa1;
beta_LU2L2 <= J_Alpa1;
elsif (sel_coef = "10") then -- Coefficient Output 3
small_a_p5 <= NL_17_param;
LARGE_A_p5 <= NL_18_param;
small_a_p3 <= NL_19_param;
LARGE_A_p3 <= NL_20_param;
small_b_p3 <= NL_21_param;
LARGE_B_p3 <= NL_22_param;
small_c_p3 <= NL_23_param;
LARGE_C_p3 <= NL_24_param;
else -- Coefficient Output 4
small_a_m5 <= NL_17_param;
LARGE_A_m5 <= NL_18_param;
small_a_m3 <= NL_19_param;
LARGE_A_m3 <= NL_20_param;
small_b_m3 <= NL_21_param;
LARGE_B_m3 <= NL_22_param;
small_c_m3 <= NL_23_param;
LARGE_C_m3 <= NL_24_param;
end if;
end process;
end rtl;
    My review
    - use the clock properly
    - learn how to use arrays (you'll have less crappy looking code)
    - more comments.
    My advice and keep in mind I ditched VHDL long ago for schematic design against my choice (but I'm never going back now that I know verilog....)
    - Split register operations from combination logic
    - Make sure all synchronous (register) operations are on a clock edge to avoid latches which are bad news in a FPGA
    - In your case use 2D indexing since you are working with groups of signals at a time. There is no need to come up with a bunch of signal names for different conditions when the condition itself can select the functionality *.
    All three of those points can be made of VHDL and verilog (and schematics in some ways) so as far as I'm concerned all three are good design practice. The first point I make I want to stress since I run into many so called "experienced designers" who don't follow that rule which makes their code a mysterious "who knows what comes out of the synthesis engine" mess......
    * Note: This isn't always true when optimizing so take with a grain of salt.
    To BadOmen:
    --- Quote Start ---
    --- Quote End ---
    I remember you warning agains starting a VHDL-Verilog war, but your comment could be the proverbial gauntlet ...
    Just giving an indication that my VHDL is a bit rusty.... 9 years rusty to be exact.
    --- Quote Start ---
    --- Quote End ---
    Your VHDL may be rusty, but my copies of the standards indicate the language itself is only slightly 'rustier' :)
    IEEE-STD-1076-2008 VHDL Language Reference Manual.pdf
    26 January 2009
    IEEE-STD-1800-2009 Verilog and SystemVerilog.pdf
    11 December 2009
