Ehab
1 year agoCMRT 6.5 & EMRT 2.0 Case (208756)
Hello Team, We hope this email finds you well. Could you please provide us with the latest versions of the following for EP2C5F256C8N: CMRT 6.5 EMRT 2.0 If these versions are not yet available, ...
Farabi_Altera
1 year agoHello, we are checking with CQE.
CMRT (Conflict Minerals Reporting Template) – Version 6.5
- This template is used to report the use of conflict minerals (tin, tantalum, tungsten, and gold, or 3TG).
- "Conflict minerals" are sourced from conflict-affected and high-risk areas (CAHRAs), and the CMRT is designed to comply with SEC’s Dodd-Frank Act Section 1502.
- Version 6.5 is just a version number of the template; the most recent may be 6.31 or earlier (as of mid-2025, RMI may not have released v6.5 yet).
EMRT (Extended Minerals Reporting Template) – Version 2.0
- This is a newer template that extends reporting to cobalt and mica.
- Used similarly to CMRT, but focused on materials not covered by Dodd-Frank but still considered high-risk.
regards,
Farabi
Ehab
1 year agoHello Team,
Hope you're well.
Just checking in on the request below—could you confirm if it’s being reviewed and let us know your estimated timeline for feedback?
Thank you in advance for your attention to this matter.
Case (208756)
