ymiler
Contributor
2 years agoclock missing
Hi, I have defined several clocks for my design, but the tool has removed some of them. Quarus (ver 22.3) found these clocks, but I'm unsure why they are not included in the final clock list. I'd ...
FvM
2 years agoInputs that are acting as actual clock won't be removed, no matter if they are correctly constrained. Clocks are removed (like other logic) if no design output depends on it.
ymiler
Contributor
2 years agoI found the issue,
I got a critical error:
" Ignored create_generated_clock , Argument -source is a collection with more than one object. "
It needs more investigate since my ENV includes Synplify Premier for synthesis and Quartus for P&R
Synplify Premier show me the clock definition correctly but the production files for Quartus include constraint with
more than 1 source objects.
Maybe I should check it with Synplify support team.
