Mikexx
1 year agoClock missing from Timing Analyzer - Report Setup Summary
I have a clock mux along the lines in "ug-qps-03-design-recommendations.pdf"
I have set the output clock to be a Global Clock in the Assignment Editor and I give it's minimum period in the sdc file. I don't get any warnings of this signal in the fitter report. It is sent to an output pin as well as used internally.
However the clock is not mentioned in the Report Setup Summary whereas the other clocks of interest are.
I've tried a couple of variations of changing name and assigning the output clock to the internal name.
Any ideas where I might be going wrong?
