Case #: 00288368 - Unable to configure Arria 10 GX FPGA Development Kit for OpenCL
I am trying to configure our Intel Arria 10 GX FPGA Development Kit for use with the OpenCL SDK by following thefollowing guide. I am able to reach "Installing the OpenCL Runtime Driver - step 3". However, when I get to the point where I try to program the flash memory "Programming the Flash memory on the Intel Arria 10 GX FPGA Development Kit - step 1,b", aocl flash is unable to detect the device. This happened after I installed the Intel SDK for OpenCL Applications version 7.0.0 (note that we need the SDK because we also use GPUs in our development environment).
Note that even before I install the SDK for OpenCL Applications, I was having an issue configuring the Arria 10 Development Kit where when I get to the last step in the guide where it asks for a hard reboot of the machine, the board is not detected anymore by the OpenCL runtime after I perform the reboot. However this is a different issue which I think might not be relevent to the first part above. I do, however, feel that there might be a hardware issue with the board not being able to boot from the on-board flash.
Please we need to be able to resolve the first issue ASAP since our research depends on it. The second issue can be tackled later.
Copying here a known issue with Ubuntu 16.04 (kernel 4.14 or newer), just in case anyone land here searching on this.
