Capture signal with SignalTap II with Storage Qualifiers
I'm not sure why you have the storage qualifier options set to Basic OR. They should be the default of Basic AND because the qualifier needs to match all the bits in your state register to the mnemonic I presume you've set up for the state names.
Also, if you haven't already, try turning on "Disable storage qualifier" temporarily (no need to recompile for this option) to make sure your actual trigger is working.
#iwork4intel
I'm not sure why either - I got desperate because I couldn't understand how it all worked :-) I did manage to figure it all out though. The biggest problem was that I had a 32bit value for my state and the mnemonic table values were defined as 5bit. I changed the state variable to 5bit and then the trigger began to work quite happily with Storage Qualifier disabled. I then enabled Storage Qualifier and it worked.
However.. I still have issues with Storage Qualifier on occasion.. I think there is an intermittent issue in there somewhere but I can live with that.
