Can't use USB Blaster on Windows 11 without disabling core isolation memory?
- 1 year ago
Thanks Frank. I successfully got the Terasic USB Blaster to work based on your advice. I had mistakenly installed version 20.1 when I thought I had installed the latest V23.1 std edition of quartus prime lite. Once I installed the latest version, I used the programmer to successfully program my version 17.0 image into the Cyclone V FPGA I am using. I can upgrade my project from 17.0 to V23.1 next. The main goal of this thread was to simply use the USB blaster on Windows 11. It works. The Terasic USB Blaster works with V23.1 std edition just fine without disabling core isolation memory. Here is the command I used to program my device: c:\intelFPGA_lite\23.1std\quartus\bin64\quartus_pgm.exe -c "USB-Blaster [USB-0]" output_files\chameleon_v2.cdf
Thanks again!
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
