15 years agocan't open read-only file
Just upgraded to 10.1 on Archlinux. Getting an error message from File-> Create/Update-> but not for all options, eg create VHDL from bdf works, create AHDL gives 'can't open read-only file', as does create symbol :(
Using 'touch' from the command line and setting other permissions to rw (646) solves the problem. I don't like setting global write permission though. Also the behaviour is inconsistant as I can create a new project etc with no problem. Setting global write on the directory didn't help either. Didn't find anything on the Altera site about this.
