Can't launch the Questa Intel FPGA Software - The path
Here are some steps to launch QuestaSim on a Windows system:
Set Up the Environment:
Ensure that QuestaSim is installed on your Windows system.
Set up the environment variables. This typically involves setting the PATH and LM_LICENSE_FILE variables. You can do this through the System Properties.
To set environment variables:
Right-click on 'This PC' or 'Computer' on the desktop or in File Explorer.
Select 'Properties'.
Click on 'Advanced system settings'.
Click on the 'Environment Variables' button.
In the 'System variables' section, click 'New' to add a new variable or 'Edit' to modify an existing one.
For PATH, add the path to the QuestaSim bin directory (e.g., C:\path\to\questasim\bin).
For LM_LICENSE_FILE, add the path to your license file (e.g., C:\path\to\license\file).
Open a Command Prompt:
Press Win + R, type cmd, and press Enter to open a Command Prompt window.
Navigate to Your Working Directory:
Use the cd command to navigate to the directory where your design files are located.
CMD
cd C:\path\to\your\design\files
Launch QuestaSim:
To start QuestaSim, type vsim in the Command Prompt and press Enter.
CMD
vsim
