12 years agoCan't launch the Modelsim-Altera Software after the compilation
My OS is Windows 7 64 bit. I'm using Quartus II 13.1 Web Edition, and Modelsim 10.1d. When I go Tools > Run Similation Tool > RTL Simulation; I get this Nativelink Error: https://www.alteraforum.com/forum/attachment.php?attachmentid=9088 I checked Tools>Options>EDA Tool Options: https://www.alteraforum.com/forum/attachment.php?attachmentid=9089 and this: https://www.alteraforum.com/forum/attachment.php?attachmentid=9090 I tried to change and add the path: "\" or "\." but don't work. Can someone help me?13 Replies
I try to re-install Quartus and Models in a different directory and now are both in folder Quartus-Modelsim and the path of simulation assigned is:
C:/Program Files/Quartus-Modelsim/modelsim_ase/win32aloem but even after the re-installation and the change of directory I have SAME problem. @kuppe I can launch the Analysis and Synthesis tool and it worked without problem. I can open Modelsim program without problem but I don't know how lauch a run simulation not started by Quartus. I am a student and I am a very beginner of Quartus but I have to learn to simulate for my exam! For the log file do you mean this? --- Quote Start --- Info: Start Nativelink Simulation process Info: NativeLink has detected VHDL design -- VHDL simulation models will be used ========= EDA Simulation Settings ===================== Sim Mode : RTL Family : cyclonev Quartus root : c:/program files/quartus-modelsim/quartus/bin64/ Quartus sim root : c:/program files/quartus-modelsim/quartus/eda/sim_lib Simulation Tool : modelsim-altera Simulation Language : vhdl Version : 93 Simulation Mode : GUI Sim Output File : Sim SDF file : Sim dir : simulation\modelsim ======================================================= Info: Starting NativeLink simulation with ModelSim-Altera software Sourced NativeLink script c:/program files/quartus-modelsim/quartus/common/tcl/internal/nativelink/modelsim.tcl Error: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path. Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option. Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: issued_nl_message Nativelink TCL script failed with errorInfo: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path. while executing "error "$emsg" "" "issued_nl_message" " (procedure "launch_sim" line 85) invoked from within "launch_sim launch_args_hash" ("eval" body line 1) invoked from within "eval launch_sim launch_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error $result $savedInfo $savedCode } else { ..." invoked from within "if [catch {eval launch_sim launch_args_hash} result ] { set status 1 if [ info exists ::errorCode ] { set savedCode $::errorCode set sav..." (procedure "run_sim" line 78) invoked from within "run_sim run_sim_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error "$result" $savedInfo $savedCode } else { er..." (procedure "run_eda_simulation_tool" line 330) invoked from within "run_eda_simulation_tool eda_opts_hash" --- Quote End ---- wolfram77
This path worked for me: C:/Program Files/Quartus-Modelsim/modelsim_ase/win32aloem
I am a student and learning to use this.
possible idea => might be if you have spaces in your project directory
--- Quote Start --- possible idea => might be if you have spaces in your project directory --- Quote End --- I have this problem for all the projects I try to simulate and they are in differents directory. - Altera_Forum
this post might help, you might need a \ added to the path
http://www.alteraforum.com/forum/showthread.php?t=43012 - Altera_Forum
Hello kchan,
Have you run at least the Analysis and Synthesis tool ? Have you checked the log file ? Can you run modelsim-altera outside the quartus enviroment ? If I were you I would change the simulation directory in something like: simulation/modelsim instead of C:\altera\13.1\modelsim_ase\win32aloem - Altera_Forum
--- Quote Start --- this post might help, you might need a \ added to the path http://www.alteraforum.com/forum/showthread.php?t=43012 --- Quote End --- Before open this thread I have already read that post and I already tried but for me that change but don't work. - Altera_Forum
Nobody can help me to fix this problem? I really need to simulate for my exam! :(
I solved this problem by putting an extra \ at the end of the path. i.e. C:\altera\13.1\modelsim_ase\win32aloem
Hopefully that is useful to someone. - Altera_Forum
Problem:
My OS is Windows 7 64 bit. I'm using Quartus II 15.0 Web Edition, and Modelsim 13.1d. I can't launch the Modsim-Altera software after the compilation and the compilation is no error and warning. I checked Tools>Options>EDA Tool Options: F:\program file(x86)\15.0\modsim_ase\win32aloem,I can't launch the ModelSim-Altera software. The path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path... I trid to change and add the path:"\" or "/" and cut the modsim_ase files to outside of the program file(x86) files.but don't work. The way of solving the problem: The path:"F:\program file(x86)\15.0\modsim_ase\win32aloem" includes a blank space,in other words,program file(x86) contains a blank space or '(' and ')'.You should change the path:for example, "F:\programfile\15.0\modsim_ase\win32aloem\", "F:\altera\15.0\modsim_ase\win32aloem\", "C:\altera\15.0\modsim_ase\win32aloem\" I try to re-install Quartus and Models in a directory and now are both in folder 15.0 and the path of simulation assigned is: F:\altera\15.0\modsim_ase\win32aloem\".It does work!!! note: 1.The install and project directory doesn't have blank space. 2.The default directory path is "C:\altera\15.0".You'd better only change the 'C' to 'F'or other disk. - Altera_Forum
Thanks for the sharing.
