- SDe_J
Do I need to do that if I'm using the signaltap ip file instead of the GUI signaltap?
I still get this error if I enable signaltap in the settings.
- sstrell
Always. You still need a .stp file for control. That's why, in most cases, it doesn't make sense to use the Signal Tap IP instantiation flow because you need the .stp file anyway.
- SDe_J
Ah. I was hoping to use this as a workaround, since I can't get signaltap to work at all (as in my other post: https://forums.intel.com/s/question/0D50P00004DnM9wSAF/signaltap-problem-with-stratix-10-production-kit)
-Sam
