9 years agoCan't instantiate Signal Tap using megafunction tool in Quartus 17.0.1
I am attempting to instantiate a signal tap core using the megafunction flow. Quartus generates the IP but when I instantiate it in my project and compile I get the following error. Error(1378...
sstrell
7 years agoAlways. You still need a .stp file for control. That's why, in most cases, it doesn't make sense to use the Signal Tap IP instantiation flow because you need the .stp file anyway.
