YousefSherif
2 years agoCan't find a PCIe simulation library for post fit simulation.
I'm using a PCIe IP "Intel Arria 10/ Cyclone 10 Hard IP For PCI Express" in my Quartus Prime Pro 21.4 design. When I generate a netlist using the "EDA Netlist Writer" tool, I find that the netlist in...
YousefSherif
2 years agoHi,
I made sure that my path was no more than 250 characters. The same problem occurs. Also, the "Launch Simulation Library Compiler" tool generates all needed libraries except for this one.
Yousef Sherif
Wincent_Altera
2 years agoHi,
Are you able to generate the design example if not in a simulation environment?
Do you search all possible libraries in the directory?
Please ensure you generated testbench simulation scripts as example below
many static design examples for simulation are only available in the
<install_dir>/ip/altera/altera_pcie/altera_pcie_a10_ed/ example_design/a10 and <install_dir>/ip/altera/altera_pcie/ altera_pcie_a10_ed/example_design/c10 directories
Wincent_Intel
