16 years ago
Cannot run the quartus 9 on CentOS 5.4
Hi all,
I recently changed my os from winxp to CentOS 5.4 , and I installed the quartus 9.0 on it successfully. But when key in "quartus" in terminal, the start window can be seen but disappear immediatelly, and such message are showed in terminal:
--- Quote Start ---
/opt/altera9.0/quartus/mw/bin-linux_optimized/rpcss.secure: /opt/altera9.0/quartus/mw/bin-linux_optimized/rpcss.secure: cannot execute binary file
Segmentation fault
--- Quote End ---
any suggestion?
Thanks in advance
    --- Quote Start ---
    No matter as normal user or root, the same response "If: expression syntax" accured when runing the install script. So I guess it's related the shell.
    --- Quote End ---
    Were you able to solve this problem? My csh is located @ /bin/csh. The first line of the script points correctly to this location, so i don't know what else to do to stop getting this "if: Expression Syntax." when i tryto run the install script.
    Cheers, Leonardo.
    [root@localhost Altera Software]# ls
    install ip_lic.txt literature nios2eds readme.txt tools
    ip license.txt modelsim_ae quartus space.txt
    [root@localhost Altera Software]# ./install
    [root@localhost Altera Software]# csh install
    [root@localhost Altera Software]# head -n 1 install # !/bin/tcsh
    Any ideas?
    something strange there, it looks like its installed already. i just grabbed 9.1-linux-free and here's my ls:
    $ ls
    adm.gz        dev_info.txt    ip_lic.txt    md5sum.txt   stub.csh
    agx_we.gz     devinfo_we.gz   libraries.gz  perlsrc.gz   stx2_we.gz
    aii_we.gz     dsp_builder.gz  license.txt   qcleanup     stx3_we.gz
    common.gz     eda.gz          linux.gz      qdesigns.gz  stx4_we.gz
    compare       gpl_lic.txt     lmf.gz        qt           stx_we.gz
    cusp.gz       gtar            m3k_we.gz     readme.txt   sys_reqs.txt
    cyc3_we.gz    gzip            m7ka_we.gz    sgxii_we.gz  tutorial.gz
    cyc4gx_we.gz  help.gz         m7k_we.gz     sgx_we.gz    version.txt
    cycii_we.gz   install         manifest.txt  sopc.gz
    cyc_we.gz     ip.gz           maxii_we.gz   space.txt
    and ./install opens up the install script and prompts me for install location. this is on Fedora 12.
    Forgot to mention i'm trying to install quartus 7.1 (it came along with the DE2-70 board... it supports stratix devices i intend to use, which is not the case for the webpack version).
    The problem seems to be in this line:
    if ($#argv > 0) then
    I'm not a csh wiz, but it looks OK to me. Trying to use quotes around the $#argv didn't solve the problem also...
    the current script has that same line so i'm not sure that's the problem.
    what i do know is that 7.1 is very old, i wouldn't go down that road.
    --- Quote Start ---
    Cheers, Leonardo.
    --- Quote End ---
    Sorry, this problem is still unsolved. I installed a clean centos 5.4 on my laptop(thinkpad x60), the same problem remained. I'll try it on an rhel 4.7 workstation after my bussiness travel.
    Wish you lucky.
    --- Quote Start ---
    --- Quote End ---
    Now,I install it on the Fedora 12,and use the bash to install, and I had installed the tcsh, in yhe install process didn't any warn.
    But I want to use bash to open the software.it's show the ALTREA's log, and end,show that
    Segmentation fault (core dumped)
    How to solve it???
