16 years ago --- Quote Start --- No matter as normal user or root, the same response "If: expression syntax" accured when runing the install script. So I guess it's related the shell. --- Quote End --- Were you able to solve this problem? My csh is located @ /bin/csh. The first line of the script points correctly to this location, so i don't know what else to do to stop getting this "if: Expression Syntax." when i tryto run the install script. Cheers, Leonardo.
