IKate
2 years agoCannot create component from template interface in Platform Designer
Hi! i try to create a component into Platform designer which includes an interface in system Verilog. I get the error "Error: Verilog HDL or VHDL XML Interface error at apescore.sv(15): port "i" ha...
- 2 years ago
Quartus Standard has limited support in SystemVerilog and you can check the Quartus Prime Standard Edition Help version > Quartus Prime Support for SystemVerilog, for the list of supported constructs.
Do note that you need to install the Intel® Quartus® Prime Help to access it.
KDB Link: https://www.intel.com/content/www/us/en/support/programmable/articles/000097917.html
For Quartus Pro, you can check it online.
Richard Tan
IKate
2 years agoHi,
i have access to both standard and Pro versions.
I see that in Pro it works.
Does this mean in Standard i can only do components with simple ports?
Is there a table describing all the features of Pro version that Standard does not provide?
best regards,
Ioannis
