12 years ago
can someone help on this
Hi all,
I am working on a finite state machine assignment. I have the following code below which i want key_0, key_1, key_2 and key_3 to influence the out LEDR[1..0] and LEDG[1..0]. key_0 and key_1 work very well when pressed the LEDG lights come on but i donot understand why key_2 and key_3 does not affect the LEDR lights when i run the code on the DE2-115 altera circuit board. I have tried to modify the code several times but still nothing happens. Thank you vhdl gurus for helping:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector (1 downto 0); -- Output
LEDG : out std_logic_vector (1 downto 0) -- Output
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,unlocked);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
process(clk, reset)
begin
if( reset = '1' ) then --Synchronous Reset
Current_State <= closed;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
Process(Current_State, key_0, key_1, key_2, key_3)
begin
LEDG <= "00"; LEDR <= "00";
case Current_State is
when closed =>
if ( key_0 = '1' ) then
Next_State <= closed;
LEDG <= "01";
else
Next_State <= opened;
LEDG <= "10";
end if;
when opened =>
if ( key_1 = '1' ) then
LEDG <= "10";
else
LEDG <= "01";
end if;
when locked =>
if ( key_2 = '1' ) then
Next_State <= locked ;
LEDR <= "10";
else
Next_State <= unlocked;
LEDR <= "01";
end if;
when unlocked =>
if (key_3 = '1' ) then
LEDR <= "01";
else
Next_State <= locked;
LEDR <= "10";
end if;
when others =>
NULL;
end case;
end process;
end Behavioral;
:confused: thanks for helping
    --- Quote Start ---
    Now all states are possible - does it work? have you run a testbench?
    --- Quote End ---
    Hi Tricky thanks again for your reply, i have run a testbench but still it does not work the way i want: i intend to have
    Key_0 pressed and LEDG(1) comes on (lights)
    Key_1 pressed and LEDG(0) comes on (lights)
    key_2 pressed and LEDR(1) comes on
    Key_3 pressed and LEDR(1), LEDR(0), LEDG(0) and LEDG(1) signifying it has come to some kind of error state which in this case is unlocked
    Below is the testbench i created can you still please take a look, other proposition from forum members are welcome as well. Feel free forum friends to add any comments that can be of help:
    -- Vhdl Test Bench template for design : uppgift_dorr
    -- Simulation tool : ModelSim-Altera (VHDL)
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    ENTITY uppgift_dorr_vhd_tst IS
    END uppgift_dorr_vhd_tst;
    ARCHITECTURE uppgift_dorr_arch OF uppgift_dorr_vhd_tst IS
    -- constants
    -- signals
    SIGNAL clk : STD_LOGIC := '0';
    SIGNAL key_0 : STD_LOGIC;
    SIGNAL key_1 : STD_LOGIC;
    SIGNAL key_2 : STD_LOGIC;
    SIGNAL key_3 : STD_LOGIC;
    SIGNAL LEDG : STD_LOGIC_VECTOR(1 DOWNTO 0);
    SIGNAL LEDR : STD_LOGIC_VECTOR(1 DOWNTO 0);
    SIGNAL reset : STD_LOGIC := '0';
    COMPONENT uppgift_dorr
    PORT (
    clk : IN STD_LOGIC;
    key_0 : IN STD_LOGIC;
    key_1 : IN STD_LOGIC;
    key_2 : IN STD_LOGIC;
    key_3 : IN STD_LOGIC;
    LEDG : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
    LEDR : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
    reset : IN STD_LOGIC
    END COMPONENT;
    BEGIN
    i1 : uppgift_dorr
    PORT MAP (
    -- list connections between master ports and signals
    clk => clk,
    key_0 => key_0,
    key_1 => key_1,
    key_2 => key_2,
    key_3 => key_3,
    LEDG => LEDG,
    LEDR => LEDR,
    reset => reset
    clk <= NOT clk after 20 ns; -- 50MHz
    reset <= '0', '1' after 100 ns;
    init : PROCESS
    -- variable declarations
    BEGIN
    key_0 <= '1';
    WAIT FOR 100 ns;
    key_1 <= '1';
    WAIT FOR 100 ns;
    key_2 <= '1';
    WAIT FOR 100 ns;
    key_3 <= '1';
    WAIT FOR 100 ns;
    key_0 <= '0';
    WAIT FOR 100 ns;
    key_1 <= '0';
    WAIT FOR 100 ns;
    key_2 <= '0';
    WAIT FOR 100 ns;
    key_3 <= '0';
    WAIT FOR 100 ns;
    WAIT;
    END PROCESS init;
    always : PROCESS
    -- optional sensitivity list
    BEGIN
    -- code executes for every event on sensitivity list
    WAIT;
    END PROCESS always;
    END uppgift_dorr_arch;
    Not sure what you really want to hear - if you have a testbench then you should be able to debug the circuit yourself as you have access to all the waveforms in the simulation.
    I will comment that the key presses hold the state machine In the state - and not change the state - is that what you intended?
    --- Quote Start ---
    --- Quote End ---
    Thanks Tricky for all your help, i have tried to implement your comment by the having the kery presses to hold the state machine in the same state but i produced a whole lot more latches again.
    I am struggling to see how i can get the code working properly. The funny thing about the wave form of the test bench in the previous case was that it gives only a few states of the code "00" and "10"
    I will continue to see how i can breakthrough this rock, your comments are still very much welcomed
