KAthu
6 years agoCan I change weak pull up status of a FPGA pin during runtime?
Hi, I know that I can enable or disable weak pull ups in the project settings and create a bit stream. But is there a way to change the weak pull up of a pin based on some logic during runtime? Is ...
ShafiqY_Intel
6 years agoHi KAthu,
Apparently, pull up the appropriate I/O based on logic is not possible.
You can only pull up it using Pin Planner or Pin assignment.
