KAthu
6 years agoCan I change weak pull up status of a FPGA pin during runtime?
Hi, I know that I can enable or disable weak pull ups in the project settings and create a bit stream. But is there a way to change the weak pull up of a pin based on some logic during runtime? Is ...
KAthu
6 years agoThank you for your reply.
Do you know how to pull up the appropriate I/O based on logic? This is what I am trying to figure out.
I could only figure out how to pull up a I/O using pin panner. But then I have to compile it to create a new bit stream. If can pull up the appropriate I/O based on some logic then I only have to compile it once.
