Yogesh
6 years agoCan DSP be used as an adder IP ?
Device used - cyclone V GT In quartus tool , if I instantiate an adder IP , I can see, tool using ALMs to make those adders. Since it's using ALMs ,max achievable frequency drops at this path . ...
CheepinC_altera
6 years agoHi,
As I understand it, you have some inquires related to implementing Adder using CV DSP block. For your information, the DSP block is primarily for multiplication. It supports pre-adder or multiply-add. It does not support single adder function. sorry for the inconvenience.
Chee Pin
