TuckerZ's avatar
TuckerZ
3 years ago
Can an IPX File handle a **?
I wanted to know if the latest version of Quartus Pro allows for ** to be used inside of path element in an .ipx file.
I tried using a ** in a path element with version 21.1 of Quartus Prime Standard and it didn't work. The user guide makes no reference as to whether this is possible.
example:
<library>
    <message>Loading now from ip.ipx</message>
    <path path="../ip/**/*" />
</library>
However, the following does work as intended:
<library>
    <path path="../ip/*/*" />
</library>
  • Recent Quartus does not allow for ** to be used inside of path element in an .ipx file. You may need to work around it using *.
  • SyafieqS's avatar
    SyafieqS
    What version or Pro does this work?
    Is it 23.2?
  • TuckerZ's avatar
    TuckerZ
    Yup, That's my question. As stated, the noted behavior was observed in "version 21.1 of Quartus Prime Standard ".
  • SyafieqS's avatar
    SyafieqS
    • TuckerZ's avatar
      TuckerZ
      Alright. I would like to request that IPX files can also use ** since other places of Quartus can use ** when searching for IP. Aligning these differences in behavior can make for a smoother software.
  • SyafieqS's avatar
    SyafieqS
    I will for a enhancement regarding this and thank you for you valuable feedback.
