TuckerZ
3 years agoCan an IPX File handle a **?
Hello, I wanted to know if the latest version of Quartus Pro allows for ** to be used inside of path element in an .ipx file. I tried using a ** in a path element with version 21.1 of Quartus Prim...
- 3 years ago
Recent Quartus does not allow for ** to be used inside of path element in an .ipx file. You may need to work around it using *.
SyafieqS
3 years agoRecent Quartus does not allow for ** to be used inside of path element in an .ipx file. You may need to work around it using *.
- TuckerZ3 years ago
Alright. I would like to request that IPX files can also use ** since other places of Quartus can use ** when searching for IP. Aligning these differences in behavior can make for a smoother software.
