BUG REPORT: VHDL 2008 target aggregate assignment leads to missing driver Warning
I received the reply from our developer. You may refer to the workaround in the test_19_4_0_64_workaround.QAR attached.
KhaiY
Hello
Well, this workaround fixes the non-working short aggregate assignment by not using the short aggregate assignment. I know how to do that, too. The point was to be able to assign multiple signals from one signal without having to explicitly write the width of each and every one of them and thus shorten the code and make it more clear and readable. I know I can make it work the same way without the aggregates. But it bugs me that it doesn't work in this specific case, even though it should.
I'm glad to see that someone was actually assigned to look into this, but this is not the result I was looking for, sadly. What I'm looking for is at least a hint suggesting that someone will try to fix the bug in the synthesis tool, even if it is in a version a year from now.
JKuba2
