Bug report have lost during the to migration myAltera to Intel website. How can I find this report?
I am asking about report #11416142 whitch mast be already exist. But I do not see them in myAltera.
1) This code compile in Quartus without any errors:
module top_module (output [7:0]my_out);
struct{enum{STAGE_1, IDLE} FSM;
logic some_register;} first_machine;
struct{enum{STAGE_2, IDLE} FSM;
logic some_register;} second_machine;
assign my_out = first_machine.IDLE;
endmoduleBut in ModelSim-Altera this code causes an error:
# ** Error: D:/Intel_Altera/Altera_projects/LITERAL/LITERAL.sv(6): Enum literal name 'IDLE' already exists.
2) This code compile in ModelSim-Altera without any errors:
struct{enum{STAGE_1, IDLE_1} FSM;
struct{enum{STAGE_2, IDLE_2} FSM;
assign my_out = IDLE_1;
endmoduleBut in Quartus this code causes an error:
Error (10161): Verilog HDL error at LITERAL.sv(25): object "IDLE_1" is not declared. Verify the object name is correct. If the name is correct, declare the object.
3) This code compile in Quartus without any errors:
assign my_out = first_machine.IDLE_1;
# ** Error: D:/Intel_Altera/Altera_projects/LITERAL/LITERAL.sv(25): Field/method name (IDLE_1) not in 'first_machine'
So, it's impossible to simulation with ModelSim-Altera and using enum inside struct.
In my opinion Quartus understanding of Verilog standard is more usable.
I want understand Intel(Altera) position. Can they force Mentor to good understanding of Verilog standard? Will they do it?
