Bug: Import of QDB file partition fails in Quartus Pro versions that use DNI
- 2 years ago
Hi @SyafieqS .
Testing with the newly released Quartus Pro 24.1, I can confirm that it fixes the original issue of this thread. Error (20045) no longer appears, and a stub file is no longer required.
As for the other two incidentally related issues that came up in this thread:
I can confirm that the erroneously produced Warning (21610) has also been fixed. With 24.1 this warning no longer appears.
However, the erroneously produced Critical Warning (24035) has not been fixed. These still appear with 24.1. And this is apparently a separate issue that's independent of the stub file issues. With 24.1 it can be observed that these warnings are generated whether or not a stub file is used.
As the original issue of this thread has been addressed in 24.1, let's close out this thread at this point. I will start a new thread to deal with the Critical Warning (24035) issue.
-Roee
Hi Roee,
These critical warnings are newly introduced design rules for bottom-up compile. They are new in 23.3/23.4
These are intentionally created and are supposed to help the customer in preventing issues with their design.
Yes all these issue discovered will be fixed in 24.1 and the plan has been submitted.
- roeekalinsky2 years ago
Contributor
Thank you, @SyafieqS .
-Roee
