Bug: Import of QDB file partition fails in Quartus Pro versions that use DNI
- 2 years ago
Hi @SyafieqS .
Testing with the newly released Quartus Pro 24.1, I can confirm that it fixes the original issue of this thread. Error (20045) no longer appears, and a stub file is no longer required.
As for the other two incidentally related issues that came up in this thread:
I can confirm that the erroneously produced Warning (21610) has also been fixed. With 24.1 this warning no longer appears.
However, the erroneously produced Critical Warning (24035) has not been fixed. These still appear with 24.1. And this is apparently a separate issue that's independent of the stub file issues. With 24.1 it can be observed that these warnings are generated whether or not a stub file is used.
As the original issue of this thread has been addressed in 24.1, let's close out this thread at this point. I will start a new thread to deal with the Critical Warning (24035) issue.
-Roee
Hi Roee,
Update from developer:
I'm seeing these critical warnings in both DNI and classic mode, so they suggest actual potential issues with the PR partitions:
Critical Warning (24035): The exported partition, "example_wrapper_level1_partition", has 2 ports being driven by the same source, "clk", outside it. Up to 10 such ports are listed below. Multiple ports sharing a source external to the partition may lead to routing conflicts in compiles that reuse this partition in another context.
Info (24036): example_wrapper_level1_i|example_core_i|clk.
Info (24036): example_wrapper_level1_i|clk.
Critical Warning (24035): The exported partition, "example_wrapper_level1_partition", has 2 ports being driven by the same source, "i1", outside it. Up to 10 such ports are listed below. Multiple ports sharing a source external to the partition may lead to routing conflicts in compiles that reuse this partition in another context.
Info (24036): example_wrapper_level1_i|example_core_i|i1.
Info (24036): example_wrapper_level1_i|i1.
Critical Warning (24035): The exported partition, "example_wrapper_level1_partition", has 2 ports being driven by the same source, "i0", outside it. Up to 10 such ports are listed below. Multiple ports sharing a source external to the partition may lead to routing conflicts in compiles that reuse this partition in another context.
Info (24036): example_wrapper_level1_i|example_core_i|i0.
Info (24036): example_wrapper_level1_i|i0.
This one only happens in DNI mode:
Warning (21610): Output port "o" in instance "example_wrapper_level1_i|example_core_i" of entity "example_core" does not have a driver. Connecting to the default value "gnd".
This warning should not be produced, This will be removed. It is otherwise innocent.
I compared the atom netlists after synthesis between DNI and classic and they are the same. I checked both 23.3 and 23.4.
Roee this should work fine. We do have extensive tests for partial reconfig in DNI mode, we were only missing the case where the design is VHDL and there is not stub.
Hi @SyafieqS ,
Re: "I'm seeing these critical warnings in both DNI and classic mode":
In what Quartus versions did you observe this?
I'm not seeing these warnings in Quartus 23.2 and earlier. I only see them in 23.3 and 23.4.
So is there still a classic mode in 23.3 and 23.4?
And are these warnings then just a separate bug that was introduced in 23.3 and 23.4 that's independent of DNI?
I'm just trying to understand the exact scope of each of these seemingly related issues.
And will all these issues that we've uncovered be fixed in 24.1? Removing the need for the stub, as well as removing the bogus warnings?
-Roee
