18 years agoBlock Design file issue
I'm trying to use a block design file (.bdf) inside a (.vhd) file. I just want to connect the input of the block inside my block file (.bdf) to the input declared in the entity within the (.vhd) file. Somehow, I need to include the .bdf file in the .vhd file, but the way I'm doing it does not work (as shown below) : For example : library ieee; use ieee.std_logic_1164.all; library altera_mf; use altera_mf.all; ------------------------------------------------------------------------ entity pll is port( clock_in : in std_logic; clock_out : out std_logic ); end pll; ------------------------------------------------------------------------ architecture pll_arch of pll is begin -- clk_in and clk_out are the PLL input and output pins respectively in the altpll megafunction. pll_instantiation : pll_block.bdf port map( clk_in => clock_in, clk_out => clock_out ); end pll_arch; ------------------------------------------------------------------------ Can we do that with QUARTUS 6.1g? - I've tried to find some info, but could not. Regards and thanks for your help.
