DNguy4's avatar
DNguy4
7 years ago
blackbox file
I have a VHDL blackbox file my_file_bb.vhd in which I declare all the input and output ports.
When I instantiate it from another program ... entity TEST: my_file port map.... Quartus keeps complaining that object my_file is used but not declared. I thought the blackbox file already takes care of all the declarations. Do I need to do anything else to use the blackbox file?
  • Vicky1's avatar
    Vicky1
    May I know any update or should I consider that case to be closed?
    Vicky
    • DNguy4's avatar
      DNguy4
      yes, it's closed. Sorry that i cannot log in for a long time.
  • sstrell's avatar
    sstrell
    Can you post your code for the black box file and the instantiation? That would help to analyze this.
    #iwork4intel
  • Abe's avatar
    Abe
    The issue here is you've used the VHDL black box module without declaring it. Before you use the BB module in your VHDL Architecture block via a Port Map, you have to declare the BB module as a Component. All you need to do is to add a component declaration for the black box module under the Architecture block and then use it in the Port Map.
    Architecture RTL of XXX Is
    Component my_file Is
    Port (
    end component;
    Begin
    Port Map ( );
    It should resolve the issue. Else post back with your code and we'll help you resolve it.
  • DNguy4's avatar
    DNguy4
    It's working now. I forgot to declare it as a component.
