The issue here is you've used the VHDL black box module without declaring it. Before you use the BB module in your VHDL Architecture block via a Port Map, you have to declare the BB module as a Component. All you need to do is to add a component declaration for the black box module under the Architecture block and then use it in the Port Map.
Architecture RTL of XXX Is
Component my_file Is
Port (
end component;
Begin
Port Map ( );
It should resolve the issue. Else post back with your code and we'll help you resolve it.
