Amirg
6 years agobit change when switching from quartus 16.1 to 20.1 pro
I was dealing with an issue for a while, and it turns out that a part of it was that some of the bit mappings were changed while switching from quartus version 16.1 to 20.1 pro. (in this case,...
CheepinC_altera
6 years agoHi, Thanks for your update. I understand that you have mentioned two IPs in the description. To ensure we are on the same page, just would like to check with you if you are currently trying to debug into the TSE IP or JESD IP? This is so that we could engage the right team to provide better assistance. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
